FIZ problem?
Discussion in 'MōVI Controller' started by Ulrik Pegelow, Mar 25, 2017.
  1. Ulrik Pegelow
    Ulrik Pegelow New Member
    Mar 25, 2017
    13
    I´m having problems with one of my 2 chrosziel cdm-100 motors. 1 is set on focus and calibrates normal and functions normal. The one set on Iris (tried zoom as well) calibrates and functions for about 30sec and then stops and I have to restart and calibrate again and then same problem reappears...
    I´m using movi controller on a movi pro. The motors are connected to the movi pro fiz directly.
    Anyone have any idea?
  3. Jair Guillen
    Jair Guillen Member
    Nov 1, 2013
    36
    I have the same problem...
  4. Martin Angulo
    Martin Angulo New Member
    Oct 19, 2014
    same here! focus is not the problem, it calibrates ok but the other axis calibrate just one minute then the message faulted appears and i lost control of them other times none of both calibrates. any advice? i need to use them and i can't.
  5. Kenny Nevor
    Kenny Nevor New Member
    Jul 25, 2017
    Are you calibrating all three at once? Or a single function at a time? I was having this issue with the new redrock fiz motors. I also noticed the motors are very sensitive to how tight they are to the lense (pressure gear to gear) I now have them lightly meshed and have not had a fault in a few sessions.
    I dont know if this is a redrock, or movi issue, but seems like a few people are having similar issues. I am also using a new Fujinon MK 18-55.
