Different behavior between TILT and PAN "Joystick Smoothing".
Discussion in 'MōVI M10' started by Nico Turini, Oct 9, 2013.
  1. Nico Turini
    Nico Turini New Member
    Aug 14, 2012
    22
    Hi everybody,
    We have just received the M10, and starting testing eveything. Very good first tests with it :)
    We have a little problem when we try to adjust the TILT and PAN behavior with the remote control option, things are not reacting in the same way.
    In the case of the PAN, when an input is given with the stick, the "Pan Joystick Smoothing" parameter offers the possibility to have a short delay, both for the start and the end of the required movement. So, when the stick is released, we can feel that we are precise to reach the panning position we want to reach.
    In the case of the TILT, things are a little bit different : the "Tilt Joystick Smoothing" parameter can't offer the same feeling : when we release the stick, it may take 1 or 1,5 seconds to stop the movement. Not the same feeling of precision.
    We have test a combination of very low values (between 0 and 5) for all of this:
    - Tilt Joystick Smoothing (0 to 10)
    - Tilt Joystick Expo (0 to 5)
    - Tilt Joystick Window (0 to 5)
    - Pan Tilt Remote Speed Adjustment is on "Independent".
    Any idea to fine tune this TILT behavior?
    Everything is with the handled config, and a Canon 5D.
    Thanks!!
    What is your tilt speed set to?
  3. Nico Turini
    Aug 14, 2012
    22
    We have tried everything for the speed tilt (from -100 to +100 regarding to the RC output). And the Tilt Speed is on a knob to adjust it.
