Canon 10-22mm question
Discussion in 'Cameras' started by Dave King, Sep 1, 2013.
  1. Dave King
    Dave King Well-Known Member
    Dec 24, 2012
    2,711
    311
    For those that have used the Canon 10-22mm lens, how much fisheye effect to does the lens have? I assume if it does have some fisheye you guys are using light room lens correction to take it out? Right now with the 7D I"m using a 20mm lens which falls just a tad short for wide property shots. I"m finding the need to be at the 400 feet limit to get real wide shots and it would be nice to have a wider lens so I don't have to go up quite as high all the time. Just seeing if the 10-22mm is a good option or if I just need to bite the bullet and go full frame 6D.
    Thoughts?
    Dave trotting out my old math the horizontal AOV of the Canon 20mm is 84 degrees. With the 1.6 crop factor that is about 52.5 degrees. At a 400 ft distance that works out to a horizontal FOV of approximately 400 ft if my math is right. The would be one really large McMansion :)
    If you go to a full frame then you would have an FOV of about 720 ft.
  3. Dave King
    Dec 24, 2012
    2,711
    311
    HI Gary
    Thanks for the info. Here's some stuff I shot yesterday. And yes it is a very large McMansion :)
  4. Dave King
    Dec 24, 2012
    2,711
    311
    Here's a picture that I shot at 400 feet to give you an idea of my limit as far as the range I have with the 20mm lens.
  5. Dave King
    Dec 24, 2012
    2,711
    311
    For comparison here's a shot I did with the Sony 760 at 400 feet.
  6. Gary Haynes
    Sounds like time to go Full Frame or get a Red Scarlet. Then you have outstanding videos and stills.
  7. Michael McVay
    Michael McVay Active Member
    Dec 31, 2012
    416
    91
    The 10-22mm is a pretty solid lens - not really any fisheye effect, but some barrel distortion that is easily corrected in LR. When I did aerial photos with a balloon system, I used this lens on a T2i because balloons are far more weight restrictive (without getting enormous). I think you would find it plenty acceptable for still photo work - especially in real estate. I used it for a long time and had a remote zoom rigged up to it which was pretty handy.
    That being said, since you do not already own it, I would give strong consideration to biting the bullet and picking up a 6D. They have come down in price a ways and I really think you would enjoy continuing to use your existing lenses on a full frame camera for aerial photography in addition to any other use you may have for it.
    If you would like, I could dig out some real estate aerials taken with a T2i and a 10-22 to help you determine which way you might want to go...
    Michael
  8. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    I shoot with a 7d and 5d3. For your purpose I'd say full frame is the way to go.
  9. Dave King
    Dec 24, 2012
    2,711
    311
    Guys thanks for the feedback. I was really trying to get by and buy some time before making a purchase to see if Canon was going to come out with a 1080 60P DSLR. Michael it sounds like you got by with a cropped sensor and the 10-22mm lens just fine. How much more head room would going from the 20mm to a 10-22mm at the widest point get me? Would you say I could get the same framed shot at 300 feet instead of 400 feet for example? It would be nice to drop my altitudes a good amount regardless if I have to go up 400 feet or not.
  10. Dave King
    Dec 24, 2012
    2,711
    311
    I don't mind having 2 camera rigs. Kinda going back and forth with whats the next video camera. I have a friend who owns a C300. I'm trying to convince him to let me try it out. :D For stills I thought for sure the 6D was considerably lighter than the 7D but it doesn't seem like it according to the specs. Less than 200 grams. I was thinking 400-500 grams.
  11. Steve Maller
    Dave, considering your objectives, I'd just find a used original 5D. I've seen the first 5D model on craigslist for $500. The image quality at low ISOs like you'll use in daylight is almost indistinguishable from the latest models, and considering the cost, you should be able to recoup your investment the first couple times you fly. Your 20mm lens on a 5D is going to give you a tremendous FOV. And just strap a $10 intervalometer on there are you're good to go. No live view, but with that FOV, you should have a decent margin of error. ;)
  12. Gary Haynes
    At 10% you would have something like 500-600 ft. Reason for the range is I don't see a horizontal AOV for the Canon 10-22 EF-S. Only the diagonal which is spec'd at 104 degrees which would be the 600ft on a diagonal dimension.
  13. Dave King
    Dec 24, 2012
    2,711
    311
    Gary
    Thanks for the response. Not sure what you mean when you say at 10% you should have something like 500-600 feet. Can you explain what you mean for those that are mentally challenged such as myself? :)
  14. Dave King
    Dec 24, 2012
    2,711
    311
    Hmmm........ I think I would rather pay the little extra money and get a used 5D MKII. I've seen them as low as $1000.
  15. Scott Stemm
    Scott Stemm Member
    Apr 10, 2013
    140
  16. Gary Haynes
    Type At 10mm the FOV should be 500-600 ft wide at your theoretical 400ft distance.
  17. Dave King
    Dec 24, 2012
    2,711
    311
    Thanks Scott and Gary, very helpful.
