i'm wondering if anyone might look at these numbers... i have a cs8 hl with tiger motors and a dual quad v3 mk bl... seems to be flying really well, and i'm lifting a two camera setup... and I just thought these numbers were odd... all the odd motors are all pulling more current... almost twice as much... should i be worried about that? any feedback would be great. thanks...steve MK Version: FC HW:2.5 SW:2.06c + NC HW:2.0 SW:2.06f BL:V3 Flight date: 30/06/2014 08:34:26 Flight time: 08:34:26.0 - 08:40:22.6 (356 secs, 00:05:56) Batt. time : 355 secs, 00:05:55 Start Lat./Lon. : 53.5536211 / -6.128649 Elevation(GPS) : 0 9.51 49.708 m (min/avg/max) Altitude(Barom.): 0 12.79 55.75 m Vertical speed : -2.46 -0.01 2.34 m/s Max speed : 31.3 km/h Max target dist.: 20.4 m Max distance/LOS: 121.6 m / 121.8 m Sats : 9 8 9 Voltage : min. 21.4, max. 23.9 V Current : 0.5 50 69.2 A Wattage : 11 1128 1619.28 W Capacity: 4940 mAh Motor1: 0.0 10.9 14.5 A Temp: 25 30 36 °C Motor2: 0.0 4.7 7.9 A Temp: 24 28 31 °C Motor3: 0.0 9.4 12.7 A Temp: 32 36 40 °C Motor4: 0.0 3.3 6.0 A Temp: 24 26 30 °C Motor5: 0.0 6.8 11.3 A Temp: 24 26 30 °C Motor6: 0.0 1.8 4.7 A Temp: 20 21 27 °C Motor7: 0.0 6.3 12.1 A Temp: 20 23 31 °C Motor8: 0.0 4.6 6.5 A Temp: 21 23 28 °C Magnet Field: 102 105 111 % (ok) Magnet Inclination: 61 68 73 deg
Steven you might want to check that all of your motors are absolutely as close to vertical alignment as possible. Your averages are pretty widely scattered.
I concur with Gary's point, but I'd also not rule out a mistake with one of your props possibly being upside-down, or a motor spinning the wrong direction. As stupid as that sounds, it's definitely possible. Ask me how I know...
