Approved Spektrum or Futaba RC Radio
Discussion in 'MōVI Pro' started by Alec Caton, Aug 2, 2018.
  1. Alec Caton
    Alec Caton New Member
    May 23, 2016
    11
    Hi Guys,
    Does anyone have any advice for a Spektrum or Futaba controller for the MoVI Pro?
    We've been using the Spektrum DX8 for our aerial work for over 5 years but our controller finally gave up. Unfortunately, the DX8 is no longer available (replaced with the second generation) but I'm not sure of its compatibility.
    In the MoVI Pro manual, page 74 it states to use only an approved Spektrum or Futaba RC Radio. ("Bind an approved Spektrum or Futaba RC radio with it’s receiver using the instructions provided by the respective RC radio manufacturer")....
    ...Does anyone know what the approved RC Radios are?
    Cheers!
    10,272
    1,144
    Alec: With the proviso that I've not tested the DX8 Gen 2, I find it hard to believe that it would not be compatible with Gen 1 -- it uses the same Spektrum protocols as the Gen 2.
    There's a thread here that may be reassuring: https://www.rcgroups.com/forums/showthread.php?2790339-DX8-Gen1-Gen2-What-Are-Differences
    Cheers
  3. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    780
    62
    alec you can use any spektrum radio with the movi the dx9 upgrade from the dx8 works just fine.
    I personally like the futaba T14SG because it has so many turny knobs to that are easy to adjust on the fly
    10,272
    1,144
    Ah yes, the turny knobs and the waggly switchy thingies! :rolleyes:
  5. Alec Caton
    May 23, 2016
    11
    Morning guys,
    Thank-you very much for the information. All very reassuring! I'll have a look into the Futaba options as well.
    Thanks again!
  6. Rick Gerard
    Rick Gerard Member
    Apr 22, 2017
    151
    20
    Any Futaba with sBus should work.
