Alexa Mini
Discussion in 'Cameras' started by Howard Dapp, Oct 1, 2015.
  1. Howard Dapp
    Howard Dapp Active Member
    Aug 18, 2012
    977
    111
    Hi Guys, for those of you who have flown/flying the Alexa Mini, how are you getting video out for your ground station? How are you powering it? Lipos?
  2. Katya Nelhams-Wright
    Jul 8, 2012
    216
    Hi Howard
    We are using a Teradek Bolt Pro 2000 SDI HDMI unit and powering the Mini with lipo and other lipo powering MOVI and Teradek.
    Kat
  3. Howard Dapp
    Aug 18, 2012
    977
    111
    Thanks Kat! Where did you source an 8-pin lemo connector pigtail for the Alexa's power port? I'm assuming you're using a lemo to deans or EC5 connector for lipo connection. Heck, while i'm at it, do you have a pinout diagram for the 8-pin lemo connector?
  4. Katya Nelhams-Wright
    Jul 8, 2012
    216
    Hi Howard.
    The lemo connector is the same as the Amira so if you have the pin configuration for that you are set. We had ours custom made by Media Blackout to EC3 connector.
    Kat
  5. Howard Dapp
    Aug 18, 2012
    977
    111
    Perfect, thanks Kat. I'll contact Media Blackout.
  6. Matt C
    Matt C New Member
    Oct 31, 2012
    15
    Hi guys,
    Do you have baseline settings I can try for me AlexaMini setup on a Multirotor?
    We a e using an 800gram superspeed lens, and powering from a 4000mah lipo direct to the cameras lemo, m15 gimbal, SDI to HDMI converter and connex.
    We seem to be fine with pan and tilt hold, but getting excessive roll wobble.
    Matt
  7. Keith Colodny
    Keith Colodny Member
    Jun 22, 2013
    32
    Is the lemo pin config the same as the red? Does the Alexa have an HDMI out that can plug into the Connex?
  8. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    It is different than Red.
    There is no HDMI output from Alexa Mini. We use Atomos Connect S2H converter.
  9. Howard Dapp
    Aug 18, 2012
    977
    111
    we recently flew the Alexa Mini with Zeiss glass and Paralinx. We ended up with an AUW of 16.8 Kg. Ozkan, what is your AUW with the mini and accessories?
  10. Ozkan Erden
    Aug 3, 2012
    678
    131
    Howard Dapp and Keith Colodny like this.
  11. Jason Herring
    Jason Herring Member
    Apr 7, 2013
    278
    What size motors and props will lift that payload? amazing
  12. Ozkan Erden
    Aug 3, 2012
    678
    131
    The copter is a modified Cinestar X8, motors are KDE 5215XF-435KV with 18" props. And also using MK + Herkules III OktoXL ESC.
    Here is a picture of this copter:
    https://instagram.com/p/6fS5-ZSXdx/
    Flying time is around 8 minutes with 2x10A 6s batteries.
  13. Keith Colodny
    Jun 22, 2013
    32
    @Ozcan Erden Thanks. How heavy is the Atomos?
  14. Ozkan Erden
    Aug 3, 2012
    678
    131
    Keith,
    Do you refer to the post that I fly Atomos Shogun with Sony A7s?
  15. Keith Colodny
    Jun 22, 2013
    32
    So how are you powering the Alexa? With standard batteries? Or Lipo?
  16. Howard Dapp
    Aug 18, 2012
    977
    111
    Same as powering the Epic, 4s lipo. The Mini is definitely not as power hungry as the Epic!
  17. Ozkan Erden
    Aug 3, 2012
    678
    131
    The same here, I use 2200 mAh 4S lipo and it is enough at least for two-three flights.
  18. Keith Colodny
    Jun 22, 2013
    32
    No, I am referring to where you said this
    "It is different than Red ,There is no HDMI output from Alexa Mini. We use Atomos Connect S2H converter. "
  19. Ozkan Erden
    Aug 3, 2012
    678
    131
    Ah, sorry.
    Yeah, that's a very little unit. It's 115 grams without battery. I power it from Movi battery with 12V UBEC, so that saves a few grams for me. With battery, it's around 200 grams.
  20. Howard Dapp
    Aug 18, 2012
    977
    111
    Ozkan, what's your motor hub > motor hub distance? Is it under or over 900mm? Just curious.
