Akira firmware
Discussion in 'Software Solutions' started by Moisess Crespo, Apr 24, 2016.
  1. Moisess Crespo
    Moisess Crespo New Member
    Apr 24, 2016
    HI! Everyone, I'm just looking for update my MOVI 10 with the new Akira firmware but I can't found where I can download it, someone can help me?
    Thanks.
    It is on the main Freefly site at the bottom of the software section.
  3. Markku Rytinki
    Markku Rytinki New Member
    Sep 6, 2013
    23
    it is still beta version? ....o_O
  4. As with all past firmware updates/releases, when you install a new version of the MoVI firmware, in order to communicate with the newer MoVI firmware, you will need to make sure you have an updated version of the MoVI app as well. MoVI App version 1.63 is not compatible with FW 5.0.
    **IMPORTANT:** Please download and read all the available release notes prior to installing or using the BETA firmware.
    As per the FW 5.0 release notes, you will need to install app version that is compatible to the new version here
    The FW 5.0 BETA (Akira) user manual can also be found here
    Software downloads by product/device can be found here
    It is under the MoVI APPS section of that link.
    The only way to take advantage of the iOS (not Mac OS) version of the app, is to have the [MōVI Wi-Fi Adapter](http://store.freeflysystems.com/collections/movi/products/movi-wifi-adapter)
    The purpose of the Freefly Systems Beta Release is to test the software before Final Release. Problems found during the Beta Release should be reported to Freefly Systems via support@freeflysystems.com for review. You may participate in the Freefly Systems Beta Release testing by downloading the software and using it, however, you recognize that the software is of pre-release quality and using Beta software for production work is done so wholly at your own risk. The software furnished by Freefly Systems for this Beta release are provided "as is." Freefly Systems makes no warranty with respect to the software and shall have no liability to participant(s).
    If you have any additional questions, please contact support@freeflysystems.com
