Quick question, probably a quick answer. How is everyone powering - Monitor, Connex & Signal Booster. Custom made cables, or from D-tap? Thanks in advance!
Lots of options - just be cautioned that the polarity of the 12V out on the Movi Controller is *reversed* for most everything you're using off that port. Here is a video my pilot put together on how to *fix* the polarity: http://forum.freeflysystems.com/ind...ler-2-pin-lemo-pins-reversed.5624/#post-55415 We use a combination off the 12V output with a splitter like this: http://www.bhphotovideo.com/c/product/1054784-REG/paralinx_rcl1_jst_rcy_to_2_pin_lemo_type.html And a lot of 2-pin Lemos with flying leads: http://www.bhphotovideo.com/c/product/845743-REG/Teradek_BIT_218_2_Pin_Lemo_to_Flying.html Just build your own cables to suit your needs. We have replaced our JST connectors with mini-Deans pretty much everywhere: http://wsdeans.com/products/plugs/micro_plug.html Those little JST connectors get loose real fast and are a real pain to maintain. The mini deans work really well, have a firm connection, and you can't connect them in reverse polarity.
