Just wondering what others are doing and the experiences you are having. The MOVI appears to only recognize 9 output channels from Spektrum or Futaba Sbus. Is there a reason for this? When trying to prepare for dual and single operator configurations, you are somewhat limited in the channels available for the MOVI. I am flying the DJI NAZA v2 using Futaba sbus. Channels 1-4 are used on the flight controls and channel 7 controls the mode. This leaves channels 5,6,8,9 for the MOVI. I assigned 5 and 6 to pan and tilt, 8 to the gimbal mode and 9 for roll trim. One question I have is can I leave the other functions like pan rate and tilt rate set to 0 on the configurator? I did not seem to have much luck with this. The gimbal was not behaving as expected. Because of a lack of time, we went back to provided DX8, satellite receiver and standard channel assignments and everything is working normally. How are you assigning channels for a single person operation? I could use pwm outputs to control the Naza and a receiver that uses the upper channels. This would free up additional channels for the MOVI. Why doesn't the MOVI decode more channels? Thanks
