Hello, Where can you adjust the settings for the smoothing in single operator mode on the Movi MR? I find that the unit is too reactive and would like to smoothen its reactions when operating solo (FPV style). I'm in airborne mode. Thanks for the Help! Regards, Justin
In airborne mode, center position on the mode switch simply locks off the gimbal for ease in takeoff and landing. In order to get smooth reactions you would be better off using handheld mode and use the center position on the mode switch to run in majestic. Be sure to set tilt to smooth lock in the majestic settings to lock tilt off while in majestic mode.
Hi Brad, Thanks for your guidance, I will use airborne mode and set the smooth lock. Much appreciated !
Smooth Lock only applies to Majestic mode and therefore would only work if you set the gimbal in Handheld mode. For your purpose, FPV flying single op, I would recommend putting your gimbal in handheld mode (even though your using it mounted to the copter) and that would then give you access to the Majestic smoothing settings.
