Hello to all I wanted to share my new octo build to to help others and to learn some new things too I have a stock MK CS8 that its maxt out on the all around weight so decided to upgrade but before I started to take apart my fine tune CS8 working copter I decided instead to first do the upgrade on a 2nd frame I had its a Skyjib8 frame that I had half way build,this are the components I had to start Skyjib 8 frame V1 8 Orbit 15-20 motors MK FC upgraded to v2.1 PH retracts and standard landing gear New components are: PowerHungry power board 8 maytech 65A Esc NO Bec Precision I2C 1 the PowerHungry distribution is pretty simple straight forward design the Esc's power leads connect very easily, I like the design because there is no soldering other than the 2 main EC5 connectors, changing a Esc in the field is as simple as disconnect and connect, the unit is a little pricey for what it is but I guess I am paying more for a well thought design than the actual materials The Precision I2C sims simple but I do have a few questions 1 to power it: instructions say that esc #1 will power the unit, is this from a Esc with a 5v bec built in, or a normal Esc? or, is it better to get power directly from the MK FC 2 The Maytech Esc dealer told me to do a throttle calibration on each Esc do I do this calibration 1 by 1 can some share the procedure for this base on my list any comments or head up would be appreciated
Ok Esc throttle calibration done did it 2 times some of the Esc audible tones where had a lower volume hmm?? is his normal tomorrow wil install the FC and the I2C
