we recently purchased a movi m15. We still have the m10 as a back up but we did not purchase a new controller. i was told by FF prior to the purchase the controller can only be paired with one unit. i wanted to unpair the controller from the m10 and pair it with the m15. i havnt really seen a thread with other people having this issue. can somebody walk me thru this? Thanks in advance -KAZU
KAZU, The Spektrum (DX7s or DX8) controller can be paired to one unit at a time. If you want to use a Spektrum Controller on the M15, you will need to either remove the Spektrum receiver from the M10, install it on the M15, and then go through the binding procedure.... or you will need to purchase a separate Spektrum receiver for the M15, install it on the M15, and then go through the Binding procedure. If you purchased an M15 without a Spektrum controller (or even a MoVI Controller) it did not ship wth a Spektrum receiver. You will need to buy direct from Spektrum... http://www.spektrumrc.com/Products/Default.aspx?ProdID=SPM9645 If you have any further questions... Please contact support at support@freeflysystems.com
that is what i am trying to do. but i do not see any threads or pages that explains how to do so. this is what my movi m15 looks like. does this have the receiver? if not i will make the purchase.
No, The receiver is not on there. Though the cable on the right side of the image is the end you plug into the Spektrum receiver.
ok im going to pickup the receiver today from a local dealer who has it in stock. can you either walk me thru or point me to a site where i can learn how to unlink and link the controller?
If you email support@freeflysystems.com I would be happy to send you the binding procedure instructions.
