The time has come. This package has served me well for many years on a lot of different jobs. Unfortunately, it has gone unused the last little bit with a bit of a work slowdown and I have some other gear needs. This package basically includes everything to be a full time Movi Op minus a ReadyRig and a cart. It's hard to pass this on, but I'm hopeful someone will pick it up and use it more often than I do Everything has been well cared for and is in perfect working order. Has almost everything that Ignite Digi makes. This package is Alexa35 ready, just need to buy the Alexa35 power to 3 Pin cable and offset plate ID makes. Below is a pretty good list of what all is included: - 1A Tools Alpha Wheels with Aluminum and Brass Wheels - 1A Tools Alpha Link Mimic - 1A Tools Alpha Link S.Bus XR - 1A Tools Cables for Movi Pro, Ronin 2, Tilta Gravity and Movi Controller - 1A Tools Brackets for Movi Controller - BNC Cables (Right Angle to Right Angle and Straight to Straight, Multiple Lengths) - Bright Tangerine Misfit Atom with 80mm/95mm Rings and Eyebrow - Cinemilled Mitchell Tiedown - Cinemilled Spindles - Cinemilled Gimbal Dock - Cinemilled Counter Weights - DJI TB50 Batteries x 8 - DJI TB50 Battery Charging Case - Ignite Digi TB50 Adapters with Lemo - Ignite Digi Power Expansion Pack (Alexa35 Ready) - Ignite Digi Offsets - Ignite Digi Top Handle - Ignite Digi Quick Release Bridgeplate - Ignite Digi Accessory Mounts - Ignite Digi 105mm Rod Bracket - Ignite Digi 80mm Rod Bracket - Ignite Digi 80mm Lens Support - Ignite Digi 60mm Rod Bracket - Ignite Digi Gimbal Mate - Ignite Digi Top Plate A - Ignite Digi Top Plate B - Ignite Digi Canon Spacer - Ignite Digi Power Breakout - Ignite Digi Kinefinity Spacer - Ignite Digi 2 Pin Lemos (Various Right Angle and Straight) - Ignite Digi 3 Pin Feeder Cable x2 - Ignite Digi Alexa to 3 Pin - Ignite Digi DSMC2 to 3 Pin - Ignite Digi Komodo to 3 Pin - Ignite Digi 4 Pin XLR to 3 Pin - Movi Pro - Movi Ring Pro and Handheld Bars - Movi Mimic Controller - Movi Controller with V- Mount Plate, Stock Reciever and FRX Pro - Movi Batteries x 8 - Movi Charger x 4 - Movi Counter Weights with Long Plate - Movi Bottom Plate - Movi Top Plate - Movi Pop N Lock 30mm, 25mm, 15mm, Screw On - MyGoGear GoCart bag - Nanuk 955 with Foam - Nanuk 935 with Foam - Nanuk 925 with Foam and Lid Organizer - Wooden Camera Alexa to 3 Pin Power Cable - Wooden Camera Alexa to DTap - Wooden Camera DSMC2 to DTap - Walter Klassen Mitch Plate with Toad - Ninja Star with Toad - Various Screws, BNC Barrels, Replacement Clamps, 15mm Rods Etc For more photos, please view this Google Drive link: https://drive.google.com/drive/folders/1NcLgwmEryw98599peyHBdCdnCKY4Gn9b?usp=sharing This package would cost over $33,000 Canadian to buy new by my rough math. Asking $20,000 Canadian or $15,000 USD. Open to offers! Certified Cheque or Wire Transfer only. Not interested in trades at this time and looking to sell as a package; not parting out.
