Just wondered if anyone had any insight to if you could map an Sbus channel to control the built in FIZ ports on the Movi Pro in order to control manual FIZ motors through a standard RC remote?! This would effectively give you the same control as through the Movi controller but over a much bigger range than the Movi controller or the mimic, specifically for drone use. Either through COM1 or COM2? The movi remote and mimic obviously access these FIZ ports so I thought it may be possible. Im looking at using the Intelli-G system for long range control of EF lenses and camera control through the built in wifi connection and thought this system could also possibly be used to control PL lenses through the Movi Pro FIZ ports. https://intelli-g.com/intellig-long-range
