Hi have a Teradek Bolt 600 that I want to mount on M10. Problem is it doesn't have internal batteries. What is everyone using to power wireless video systems? Looking into v mount batts for another project, but haven't found one under 2 lbs, plus bracket. Can I use lipos?
Not sure this is an "Announcement," post, but I recently went through the same exercise and settled on IDC Duo 95 - two d taps and one USB. Attach w a cheese plate and velcro. Clocks in just under your 2 lbs target.
Good point should have been on M10, I was in a hurry. Thanks though. IDX? or IDC? Never heard of IDC. Where did you buy?
You didn't have to re-post, I've let the mods know and they'll move it. IDX indeed - Many places carry them: http://www.bhphotovideo.com/c/product/962827-REG/idx_duo_95_li_ion_v_mount_battery.html Switronix also has a jetpack solution if you need Lemo in addition to d tap and USB: http://www.bhphotovideo.com/bnh/con...s&sts=ma&Top+Nav-Search&Ntt=Switronix jetpack
No concerns, they just said that they use Sony L batts a lot and they last at least 2 to 3 hrs which is good for me. The ones you mentioned worked too. I just needed lighter weight.
