I've been using my Movi Pro handheld for a while. Is there anything that needs to be done to run it inverted or upside down? I want to mount it without the ring and the toad in the hole is on the bottom? I want to put it on a jib. Do I simply rebalance and go or are there some settings I need to set in the software? --Jeff
I just pause the motors (or turn it off), invert it by swinging the pan tubes over the right side of the camera and then underneath, then mount it and either re-boot or activate the motors again. Nothing to change, it should just auto-sense.
