Toad on a stick - Can be mounted "upwards"?
Discussion in 'MōVI Pro' started by Xavi Guillen, Oct 15, 2017.
  1. Xavi Guillen
    Xavi Guillen New Member
    May 16, 2017
    Hi, I'm planing to rig the Movi on a 45mm grip tube with a baby pin big ben for top shooting. Does anyone know if the "Toad on a stick" (or more accurately, the screw locking into the baby pin) is designed to hold the Movi not sitting on the pin but hanging from it? I hope I've made my self clear. Thanks!
  2. Graham Futerfas
    1,221
    239
    I'm not sure of the actual design specs... that's a question for Freefly Engineers.
    I personally would use the Ninja Star for a rig like this, but it really depends on the weight of your camera and Movi setup. With a lighter camera, it's probably OK. I had a really heavy setup the other day that I definitely wouldn't rig to an upside down Toad on a Stick... it was over 30 lbs. altogether.
    If nothing else, use a lanyard or webbing as a safety line. We usually run it through the pan tubes, in case the Toad gives out.
    Xavi Guillen and Bryan Edmonds like this.
  3. Kurt Wallrath
    Kurt Wallrath Member
    Nov 8, 2013
    135
    21
    I wouldn't even exercise that idea! Use a toad and ninja star.
  4. Xavi Guillen
    May 16, 2017
    I'll be using the ninja star. Quick stupid question here: today I unboxed my new movi pro (after a while working with other companies Movi) and I'm curious about what's the rubber/carpet tape that comes with the Pro, any idea :p? Thanks graham for your general contributions!
    #4 Xavi Guillen, Oct 18, 2017
  5. Xavi Guillen
    May 16, 2017
    I'll definietely use the ninja star. Thanks!
  6. Jake Wilganowski
    Jan 5, 2017
    43
    I wondered the same. It's to wrap around the ring for grip.
