Hi Guys, I'm trying to set the Movi M10 to have no smoothing of any kind on the pan and tilt for fast movement. I've set everything at 0 on pan joystick smoothing and also the expo same for tilt and wound up the speed for both pan and tilt. I've got good response on the pan but when tilting the tilt has a delay after you let go off the stick but it's not the same for the pan. Is this a limitation on the controls and the Movi? Any advice welcome thanks
*****Update**** The Movi was at its capacity and although to me the pan was faster acting compared to the tilt I've been told it's a firmware thing which will be fixed in the future, thanks to the quick support of Tabb@Freefly I was happier to know that was its limit.
