MoviPro Power Solution - Anyone seen this???
Discussion in 'MōVI Pro' started by Chris Ray, Sep 6, 2017.
Tags:
  1. Jake Wilganowski
    Jan 5, 2017
    43
    Nope but I just bought the ignite digi version, I like it better because the cable isn't integrated, cables go bad
    SeBaStIaN BArrEtT likes this.
  2. SeBaStIaN BArrEtT
    Oct 30, 2016
    343
    67
  3. Graham Futerfas
    1,221
    239
    Ignite says you need pretty large V-mounts -- 120wH minimum -- or a 24V block battery. Since most of my camera batts are 95wH, I'm not sure if they'd work, but Julie at Vaxxis says any camera battery will do.
    Movi Pro is 24V, so these adapters are stepping up the voltage.
    I'm not sure I see the point of this particular adapter over Movi Pro batteries. Can anyone point out a good use for it that I'm missing? Longer run time? Not having to buy Movi Pro batteries? The cable looks pretty short to be useful outside of mounted to the Ring.
  4. Jake Wilganowski
    Jan 5, 2017
    43
    It's because movi pro batteries are not 100 percent reliable in my opinion and experience
    And bigger batteries for longer run times can be useful in a ton of scenarios
    And a professional is always prepared for any situation
    And the Anton baur 95w batteries will work as they are 10amp if you want to stay smaller
    Melqui Rodriguez likes this.
  5. Jake Wilganowski
    Jan 5, 2017
    43
    The ignite digi version has a port for a cable so you can get any length you want, it's standard arri 2 pin lemo
  6. Graham Futerfas
    1,221
    239
    Hi Jake, I think highly of the Ignite Digi adapter, but this Vaxis one seems more limited and my comments are directed at it specifically.
  7. SeBaStIaN BArrEtT
    Oct 30, 2016
    343
    67
    there is no real point besides solving any power draw issues or reliability issues with movi pro batteries. Dunno if it even solves power draw issues, and is pretty inefficient form factor for sure.
  8. Tom Waugh
    Tom Waugh New Member
    Nov 12, 2013
    14
    Hey Graham,
    Just clarifying here as well as the other thread sorry.
    Our adapter requires batteries that can output 10A or ~120W. They don't need to be 120Wh+.
    IDX made thes 95Wh E-HL10DS which work well.
    http://www.idxtek.com/products/e-hl10ds/
    Cheers,
    Tom
