Movi pro and Spektrum BIND.
Discussion in 'MōVI Pro' started by luigi valtulini, Dec 3, 2016.
  1. luigi valtulini
    luigi valtulini New Member
    Sep 11, 2013
    11
    Hello ,
    my Movi Pro is arrived today, i try to bind with my new Spektrum DXe but not way.
    I use DMX2048 but not work.
    Anyone have a solution?
    thanks a lot
  2. Graham Futerfas
    1,258
    243
    Did you get a Spektrum to COM cable? I got my Movi Pro today, but the Spektrum cable is the one thing that didn't ship yet.
  3. luigi valtulini
    Sep 11, 2013
    11
    Ciao Graham, thanks for the reply.
    Why do I have to have a COM cable?
    I thought it was enough to bind as in the manual to assign the transmitter.
    I must make a special procedure?
  4. Graham Futerfas
    1,258
    243
    Ciao Luigi!
    I'm not really familiar with the Spektrum DXe, but it looks like a lower-cost controller. I can't tell if it will work for the Movi -- it may not. You probably should contact Freefly Support and ask them: support@freeflysystems.com
    I used a DX7s with my Movi, and the receiver was the AR8000 (just the little satellite part of it): https://www.spektrumrc.com/Products/Default.aspx?ProdID=SPMAR8000
    You need to connect a receiver to the Movi Pro for it to receive a Spektrum signal, and that requires a COM port cable. This is the cable that Freefly sells to adapt the Spektrum satellite receiver to the Movi: http://store.freeflysystems.com/collections/movi-pro/products/movi-pro-com-to-spektrum-cable
    It was the one thing that didn't ship with the Movi Pro this week, so when you said you had a Spektrum, I got excited that maybe you'd received the cable. I need it to plug in my Veracity Wheels from PLC.
    This is a photo of the little AR8000 satellite receiver on my old Movi M15:
  5. luigi valtulini
    Sep 11, 2013
    11
    Thanks a lot Graham ;)
