Movi knocks horizon left
Discussion in 'Movi Technical' started by viktor manshtein, Feb 23, 2019.
  1. viktor manshtein
    viktor manshtein New Member
    Feb 1, 2019
    25
    11
    Help, Movi knocks horizon left
    When Roll is blocked, Movi collapses the horizon line.
    Balancing the iPhone is perfect.
    How is it possible to cure?
  2. Pavel Houda
    Pavel Houda Member
    Jan 15, 2019
    75
    25
    Hello Victor,
    I am not sure if I fully understand your question. In the latest beta there is a way to adjust the roll when that axis is locked. I hope this helps.
  3. viktor manshtein
    Feb 1, 2019
    25
    11
    Hi Pavel,
    Thanks for the tip)
    Are you talking about version 1.2.6?
    in which section of the menu is it?
  4. Pavel Houda
    Pavel Houda Member
    Jan 15, 2019
    75
    25
    Hi Victor,
    It's a beta release. You will have to sign in as a beta tester, then you load it through "Testflight" App. My revision is 1.3.0. (My iPhone says 1.3.0 is the latest version, the web site says it is 1.3.2). It's in Movi>Robot>Main Settings>Roll Trim. Fourth item from the top. The App is on their support page: https://freeflysystems.com/support/movi-support/beta . There is also "beta" section on these Movi Forums, but there is not much there. Mostly people complaining about lack of new releases.
    #4 Pavel Houda, Feb 24, 2019
  5. viktor manshtein
    Feb 1, 2019
    25
    11
    Thanks Pavel,
    I will try to install this version
