M5 / AKIRA / ISSU / pan hard vibration / Airborn
Discussion in 'MōVI M5' started by Guillaume MARION, Apr 6, 2016.
  1. Guillaume MARION
    Dec 21, 2014
    77
    15
    HI there,
    Any one got trouble with AKIRA? installed, tested in handled and was working fine, then put in airborne and under the ALTA. Pan was vibrating a lot and impossible to remove it...
    Any other experiment this??
    Thanks a lot
  2. Marc DIDIER
    Marc DIDIER New Member
    Jun 10, 2014
    Hello Guillaume,
    It seems to be a too light setup for the M5 when airborn...
    http://forum.freeflysystems.com/index.php?threads/alta-m5-image-stability.7673/#post-69245
    Handheld, movie works great, airborn is another story !
    We are fighting against vibrations since we recieved the Alta. It brings a lot of vibrations.
    Tune your Alta first ( green dampers might help), then play with the Movi ( expert settings). If nothing goes better, last thing to do is to add weight on the M5 ( I know it sounds stupid as the M5 is supposed to work with small & lightweight cameras :-((. )
    If you are, let's say in Nepal above 3000 m, you won't love this last option !
    Salutations à bruno !
    Marc@Aeromaker
  3. Romand Walter
    Romand Walter New Member
    Jan 5, 2013
    10
    Salut les Français ;)
    We tried Akira with an A7S set up but we moved back the last firmware. It worked well when you don't move the drone, but it was very shaky otherwise....
