M-Series still the most experienced RC camera car on the market.
Discussion in 'Freefly Tero' started by Rob Drewett, Nov 4, 2019.
  1. Rob Drewett
    Rob Drewett Member
    Oct 6, 2013
    36
    21
    If you don't want to just buy a converted RC car that has had a ISO wire plate stuck on top please check out our M-Series product range http://motion-impossible.com/products/m-series/
    You can add different stabilizers on to suit your way of filming, our V-Con not only takes out micro-vibration (same as ISO wire) but can also remove unwanted vertical movement with its ingenious shock damping system, whilst taking payloads up to 15kg/33lbs (camera & gimbal).
    The V-Con XL is the high-level vertical axis stabilizer, so your camera does not just have to work at shin height. It fits simply on to the standard mounting rails on the M-Series.
    If you're filming in VR you can then turn it into the 360 EVO. The 360 Evo is designed to fit on to the V-Con XL, and utilizes gyro stabilization to eliminate roll, tilt, and vibration in 360 camera arrays.
    M-Series was built for moving cameras.
    You get what you pay for!
    Email us at info@motion-impossible.com and quote "Rover" for a 10% discount.
