JOYSTICK FOR MOVI IN ALU BODY
Discussion in 'MōVI FAQ - Tips and Tricks' started by Roger Fosaas, Jan 31, 2016.
  1. Roger Fosaas
    Roger Fosaas New Member
    Aug 9, 2015
    25
  2. Walter Brokx
    Walter Brokx New Member
    Feb 23, 2016
    27
    I tested it in september 2015, but not very extensively.
    With the suggested settings I found it making the MoVI move pretty fast, so I tried tweaking those settings:
    that resulted in more subtle movements, but also in a strange upward tilt jump every 30 seconds. (So after a few minutes it was tilted up a few degrees.
    I guess I did something wrong, but haven't had the time (or urgency) to figure it out yet.
    Most important thing I need to check is whether the suggested settings are without the tilt jump.
    I figured this could be handy when shooting on a boat while you still want to be able to set the tilt without a second operator.
    Just beware that if you connect this: the MoVI won't respond to a remote anymore, unless the joystick is disconnected AND the remote is bound again. The MoVI will only accept 1 input at a time.
    Roger Fosaas likes this.
  3. Wolf Schiebel
    Wolf Schiebel Active Member
    Aug 15, 2012
    254
    67
    Hi, nope, i have three controls installed simultanously, Futaba FX-30, my Thumbcontroller (Spektrum) and Mimic without any problems. I just switch between the Spektrum and Futaba receiver in the app, the Mimic overrides any settings of the rc receivers. No need for re-binding whatsoever.
    Best,
    Wolf
  4. Walter Brokx
    Feb 23, 2016
    27
    That is what I expected how it would work, but I really had to rebind everytime.
    I will do more tests later: it would be weird if it works for you, but not for me.
    I hope you are right, Wolf, but when I ran into troubles with it Freefly confirmed that I had to rebind.
