hey, i am really struggeling with my movi pro on an alta 8 pro and my other big hexa. i dont know if this issue is related to drone vibrations or is it the movi acting weird. if you please could check out the short example clip https://vimeo.com/manage/videos/675858643 on the alta i tried every color of the provided dampers, on the hexa i tried it with different wire rope isolators and the freefly dampers - always the same. so i guess its coming from the movi. setup is really well balanced and also not the heaviest, about 2kg. i did autotune with the gimbal hanging on the drone sitting on its arms and while hovering in the air. i am using the ignite tb50 adapters and tilt offsets. i checked every screws and everything attached is as rigid as possible. i appreaciate any tips. thanks a lot
