Ideal Klassen Wheels Settings for MōVI Pro
Discussion in 'MōVI Pro' started by Justin Scott Brown, Oct 11, 2017.
  1. Justin Scott Brown
    Justin Scott Brown New Member
    Nov 2, 2016
    Hey guys,
    Headed out on a feature this week and need to use wheels. Got the Klassen ones up and running but it seems I need to tune down the Pro more than I'd like to prevent oscillations when in use. Here are my settings:
    General Menu:
    • Gimbal Applicaiton = Handheld
    Remote Operator Config Menu:
    • Pan Joystick Smoothing = 0
    • Pan Joystick Expo = 0
    • Pan Joystick Window = 5 uS
    • Tilt Joystick Smoothing = 0
    • Tilt Joystick Expo = 0
    • Tilt Joystick Window = 5 uS
    • Pan/Tilt Remote Speed Adjustment = Independent
    • Tilt Control mode = Rate
    Remote Rate Scale is set to around 100 under Dual Op Adjustments in the Freefly app.
    Remote Controller Config Menu:
    • Radio type = s.bus
    • Map Remote Mode = 6
    • Map Remote Pan = 1
    • Map Remote Pan Rate = 5* (for the M15 Klassen said 7 was ideal)
    • Map Remote Tilt = 2
    • Map remote Tilt Rate = 5* (for the M15 Klassen said 7 was ideal)
    • Map Remote Roll Trim = 5* (for the M15 Klassen said 4 was ideal)
    • Map Remote Shutter = 8
    * In order to get the desired 1500uS readings for Pan Rate, Tilt Rate and Roll Trim, I adjusted accordingly as described above.
    Switch Config:
    • Left switch = 6
    • Right switch = 7
    The Futaba radios trim setting are all set to 15 on the wheels.
    Axis Output:
    • Pan Axis Output = Rate
    • Tilt Axis Output = Rate
    • Roll Axis Output = Angle
    Any ideas or tips for optimal use? Thanks!
  2. James Layton ACO
    James Layton ACO New Member
    Aug 1, 2015
    20
    Hi Justin,
    Did you ever get anywhere with this? We’re in the same boat with the XL...!
  3. Justin Scott Brown
    Nov 2, 2016
    Hi James, no one has reached out yet. I would keep an eye on the remote rates as I stated above because the desired 1500uS readings required different values than the M15. Other than that, just tuning to the aggressiveness of your wheels will hopefully yield desirable results.
    I found I could tune higher if the DP didn't need the wheels to be as reactive (Remote Rate Scale was set to around 100 under Dual Op Adjustments for my DP to start. Tried to get it lower whenever possible).
  4. Nick Timmons
    Nick Timmons New Member
    Dec 17, 2016
    Or just upgrade your wheels... The $1000 update makes this a thing of the past, for the most part.
  5. Justin Scott Brown
    Nov 2, 2016
    Haha I don't think I'd upgrade wheels I rented but I'll let my buddy know.
