I'd like to know hatter largest batteries people are using with the free fly clock adaptor + red epic on the Movi m15 I interested in getting a set of the new IDX Duo 95 batteries or the switronox hypercore98 Has anyone tried them? Will they fit?
Tested last weak some 95w v-lock, balance with redrock on the other side, no prob! Here is a picture : https://www.facebook.com/PolesDimages/photos/pcb.738908506193449/738907576193542/?type=1&theater
Is that an m10 or M15? Are those the IDX Duo 95? do you know how many centimetres deep the batteries are?
Batterie type IDX E-7S Référence : CN-SON-65H-ST Capacité : 6600 mAh Technologie : Li-ion Tension : 14.8 V Couleur : Noir Poids : 696 g Longueur : 141 mm Largeur : 84 mm Hauteur : 47 mm
I see that freefly recommend using an IDX endura 7S battery to power the epic. Though I read on IDX spec sheet for the battery that its maximum discharge current is 51W whereas the RED user manual says the camera draws on average 60W shooting 5K at 24 fps. How are you managing to use this battery with the RED EPIC? either the data provided by IDX or by RED is incorrect. Anyone care to shed some light?
I can´t tell about the IDX but i use similar Bebob 75 Wh (max. discharge 5 A = about 60 W) together with ff Heden Carat without any issues... Even with Dragon and 6 K/100 Frames Best Wolf
Bevan, I've never had an issue powering an Epic, Cmotion w/ Heden M21 motor with an IDX Endura 7S. It usually lasts 40 minutes to an hour.
Here are some specs found on B&H for the IDX duo batteries: Dimensions : 3.82 x 5.75 x 2.32" (9.7 x 14.6 x 5.9 cm) Maximum disharge current : 6.3 A / 76 W (total with D-Taps and USB) D-Taps: 4.1 A / 50 W each USB: 1 A / 5 W I own 2 of these batteries.. Mainly used to power accessories on my m10.
Hi Bevan We are using a set of 4x Li95S battery pack with 4ch charger. http://www.globalmediapro.com/dp/A2...HW-R-Lithium-ion-Battery-95WH-for-Red-Camera/
