Installed a Flysight Black Mamba TX5820 V2 Transmitter on my Alta this evening and things did not go very well until I compared the cables that came with the transmitter and the cable that came in my Alta bundle. The power leads were reversed. I checked the forums and the web to see if this was a common problem but did not find anyone else with the issue. It did not appear to be a common problem. Fortunately, the transmitter's power connector is idiot proof so nothing blew up. Using some very small tools I was able to successfully remove the red and black wires and switch places. Now everything is perfect. It probably would be a good idea for the QC department to check the cables that are included with the Altas and make sure they are wired correctly. If anyone else has trouble mounting a transmitter I hope this helps them resolve the issue.
Thanks for Rick Gerard !!! I have the same problem, the picture below is my Alta bundle cable. Fortunately, the transmitter's power connector is idiot proof so nothing blew up.
Alta fpv cables are wired for ImmersionRC vtx which is different that the Black Mamba so it is not a Freefly QC problem. As someone who has been flying fpv for almost 2 decades now, I would not recommend using a 1 watt vtx on a multi rotor. That is a lot of RF energy around the other electronics. You are far better off investing in high quality antennas for both the transmitter and receiver. And if penetration of the video signal is your problem then look to 1.3ghz or 900mhz band.
Mark, What TX and antenna combo would you recommend. I've gone through a bunch of antennas and FPV is still the weakest part of my setup. My little Mavic Pro delivers perfect video to my phone from insane distances. DJI's Inspire 2 is the same. Getting the video to the camera operator and the pilot shouldn't be that much of a problem. I would at least like to be able to see the heading info. Going to upgrade to Alta Pro soon and hopefully, that will be part of the upgrade.
I fly with a 1.3 ghz 400 watt vtx on the bird and fly with these antennas vas-bluebeam-pro-1.3ghz-antenna If you fly in an urban area with lots of rf and steel structures 5.8ghz will generally have issues and flying any analogue system takes some experience to learn its limits and how to fly with them.
I think you mean 400 mW... I have not checked yet but I think 1.3 GHz radios require an amateur radio license.
Most of the 5.8ghz radios also require a license if operated at higher than 25mw. and yes I did mean 400mw.
I just purchased this transmitter for my Alta 8 and was curious how you installed it. I’m replacing the stock FPV from Freefly and don’t want to wire it incorrectly. Any help is appreciated. Thanks!
There is a stock cable that comes from freefly. Its plug and play. there is more instructions in the manual also but its an easy job.
