Extension Rods for M5
Discussion in 'MōVI M5' started by AlexanderEberhard, Sep 4, 2020.
  1. AlexanderEberhard
    AlexanderEberhard New Member
    Oct 18, 2017
    Hey guys, my c200 is slightly to high to fit in the cage. Any idea where to order longer and fitting side rods for the M5 cage? So a replacement.
    Also, where do it get 3/8 mounting screws for the M5 baseplate?
    Thx, Alex
    #1 AlexanderEberhard, Sep 4, 2020
  2. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    847
    67
    Are talking about the side rods 2 bars or the roll bars? the old cinestar is perfect size to extend the side bars but the side rods you can find them online
  3. AlexanderEberhard
    Oct 18, 2017
    Thx mate. Yes I mean the side rods. All I found is that but it looks like a full cage and not bigger?
    http://brushlessgimbal.ca/BRUSHLESS-GIMBAL-PTZ/Digital-SLR/Tilt-Bar-System-For-BG003-Pro-Gimbal
    Can simply but movi 300 mm rods and cut them to the desired length? I'd also need the ends for the rods like on the original. Will 1-2 cm longer side rods through the balance of as long it with in the system? Could do right?
  4. Jason Smoker
    Oct 23, 2012
    847
    67
    Yes you can just cut them. They have ends have caps so you can just pull them out and put them into the new ones.
    I extended my side bars without any problems im sure you could do it with the side rods :)
    AlexanderEberhard likes this.
  5. AlexanderEberhard
    Oct 18, 2017
    Thx mate! So I could get these and cut them? (Do they fit?)
    https://store.freeflysystems.com/products/19mm-x-300mm-carbon-lens-rod?_pos=5&_sid=5b6bfc227&_ss=r
    And use the old end caps of my shorter side rods? Or can the end caps been ordered separately?
  6. Jason Smoker
    Oct 23, 2012
    847
    67
  7. AlexanderEberhard
    Oct 18, 2017
    Jason Smoker likes this.
