Hi all I have watched all the training videos regarding assembling and balancing, etc. But next will need to connect the gimbal servos to the MK FlightCtrl. Unable to find the correct procedure for this (yet). Looking for: Initial MKTool settings to use (screenshots?) First connection of gimbal (likely pots will be out, do I need to disconnect belts, etc?) Using a 5v BEC (with 2s 1000mAh battery) to power the servos, and only 1 transmission line from the MK FlightCtrl seems to be the ideal method, but any details would help... I have a rough idea what needs doing, but would prefer not to learn the hard way. Will be doing this over the next few days. tks in advance.
Hello John, Most of what you will need to set that up can be found here: http://www.quadrocopter.us/support/downloads/ Here you can find setup videos as well as firmware for the MK FlightCtrl. Greetings, Adam
