Hi, i made this little custom part for a friend to install his Iftrontech " Wattzilla" video Tx on his CS8. If you need them, i have the DXF , CamBam + Gcode files for Mach 3 milling , these files a re free to use / reproduce of course ( to be milled with a 1,5 mm upcut cut tool at 16 000 RPM, in 1,5 mm thickness carbon) . I did program slow advance and speeds especially for drilling the holes to take into consideration the flex on standard CNC router Z axis and not to stress the milling tool. I only made a small mistake for the lower hole position for the M2 screw for the video TX fixation, which needs to be a bit higher. To install on the booms, all you need is 2 pairs of plastic clamps with their screws and M2x6 or M2x8 screws and nuts ( x2). Best regards, Fabien
