Alternative Power Solutions for X
Discussion in 'ALTA X' started by Daniel Waghorne, Feb 5, 2020.
  1. Daniel Waghorne
    Mar 8, 2018
    30
    Hey everyone,
    I'd like to see if there are alternative power solutions for powering the Alta X in order to keep it under 55lbs. Currently, the Alta X with the Flight Packs from Freefly and the Movi Pro attached sits as 49.26lbs with no camera attached. Being able to carry less than 6lbs of camera is laughable if you're trying to fly legally in the US.
    I currently own another system that requires two 12s packs, but I'm running four 8,000mah Tattu batteries in series, which is half the weight of the current battery setup as each weighs 2.39lbs. Albeit the flight time is less, but that's not important to me.
    Any other options would be great as I can't find smaller flight packs that Freefly offers.
  2. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    878
    70
  3. Daniel Waghorne
    Mar 8, 2018
    30
    Thanks Jason, but ideally I'm looking to save 4kg's. Basically something that would be the same weight as 4x 8,000mah Tattu 6s batteries.
  4. Jose Luis Ocejo
    Jose Luis Ocejo Active Member
    Sep 20, 2012
    581
    44
    Look up Kopterworks in europe they came out with a Alta X custom plate for individual lipos
    Daniel Waghorne likes this.
