Hi, Do anybody know a alternativ to the MöVi Lipos? Specs: Battery Type: Lithium Polymer Capacity: 2.6Ah Voltage: 14.8v Max Continuous Discharge: 3C (7.8A) Max Burst Discharge: 5C (13A) Max Charge Voltage: 4.2V per cell Minimum Discharge Voltage: 3.0V per cell Dimensions: [100mm (L) x 25mm (W) x 30mm (H)] Weight: 200g Br, Martin
There sure are several alternatives, as long as the voltage is the same, you can use them. The dimensions might be a problem though.
It's hard to find lipo with so low "C" value. Usually lipo with 14,8 v has 20-30 C , but the most problem is the dimension!
