Hi, I am looking for the best way to transport our drone, gimbal and accessories for in pelican cases as ready as possible for shooting. Are there any cases with premade foam for all this? I know the Alta comes in a case, but what about the movi m10 with landing gear? I know of cases for the controller. Any tips? Cheers Eirik Nicolai Heim Crux Film Norway
I'm not sure if this will help you, but this case will accommodate the M10, with the landing gear popped off and stored in the large front area pocket And this case would be for the controller.
Nice work there! Could I have the Movi totally ready for a shoot inside that case, when not having it up in the air? Just place the camera and go.
Yes, its certainly possible to leave the camera attached to the Movi inside the case and some operators choose to do it that way to save set up time. Depending on the size of your camera, it may be a bit more spacious to go with this case which is designed to accommodate the Movi with the Full Cage. It should have ample room for a camera as well.
Ok. Thank you. I will mainly be shooting with our Red Epic, sometimes a Canon 1DC. The top handle can stay on with this case as well as the top bar with handles?
i have a cinema oxide case for the old M10 (without fullcage and without toad). could i replace just the foam to have the case for M10 fullcage, new landing gear and toad installed on both MoVI and handle?
Hi Rolf, We do foam replacements all the time. And we can customize the foam to your liking/needs. Give us a call and we'll get you set up. 212-786-2280 or 800-601-8816
