Hi, I am very satisfied with how my my alta+movi m10+red works together. Using the futaba and movi controller and flying almost always as dual ops. I have used up to 50mm lenses until now and I know how to tune it well and I am really satisfied with not having to do any stabilisation in post. Any out there with experience with the allrounder 24-105? Does it work well at 105mm? If you tune the set up with the zoom in midle position, are you able to use the whole range without doing any tuning when going from 24 to 105 for example? No problem with doing mini adjustment to the cage, but is that enough to still get smooth images? I will have a focus motor when flying with this lens when not only using 24mm to get proper focus. The canon 16-35mm f2.8 works like a charm, but it is internal zoom and I guess the weight does not change that much. I tune with that lens at 24 mm and I get good results at the whole range now and have the setting stored.
