Aero landing gear tube diameter
Discussion in 'ALTA' started by Iacopo Boccalari, Feb 11, 2016.
  1. Iacopo Boccalari
    Iacopo Boccalari New Member
    Jul 16, 2014
    We've purchased a used ALTA at my company and it's movi has the old CineStar-like landing gear.
    We've just ordered the new aero landing gear and I'd like to build some custom accessories to be mounted on its legs.
    Can anyone tell me the diameter of the legs so that I can start designing what I need before receiving the landing gear itself? :)
    I suppose it's the same diameter as the smaller tubes on the movi M5 cage, but I'd like to be 100% sure before designing!
    Thank you guys!
  2. Dimitar Krustev
    Dimitar Krustev New Member
    Jan 15, 2015
    25
    20
    As I know the diameter is 15mm, not 100% sure because I am using CineStar-like landing gear on my Alta, but when I made a research I found out that is 15mm which is bigger than the MoVI cage tubes.
    Cheers
    Iacopo Boccalari likes this.
