Zenmuse H3-3D gimbal on Cinestar 8 HL
Discussion in 'Cinestar 8' started by Hank Perritt, Jul 27, 2014.
  1. Hank Perritt
    Hank Perritt New Member
    Jul 26, 2014
    Does anyone have experience, successful or otherwise, in adapting a Zenmuse H3-3D gimbal to work on a Cinestar 8 HL?
    I realize the Zenmuse is designed for plug-and-play with the Phantom, but getting power to the gimbal from the CS 8 is not a problem, and it seems like there should be some way to feed the servo outputs from the MK FCB 2.5 on the CS 8 to the axis signal inputs on the Zenmuse.
  2. Brandon Loeser
    Nov 11, 2012
    70
    The Zenmuse system is only compatible with DJI flight controllers. It won't work without them so you can't hook it up to a MK system.
    Compatible With DJI Flight Control Systems
    The H3-2D/3D gimbal is compatible with DJI flight control systems, it can adjust the roll and pitch angle according to the accurate control of the Gimbal feedback and communicate with the MC in real-time.
    • It supports WooKong-M, NAZA-M V1, NAZA-M V2, Phantom;
    • It will support Ace One, WooKong-H, NAZA-H;
