Just a quick question. I mount my 3s 1200 mah pack where the instructions say to mount the yaw radian. Would it totally screw up everything if I mounted it on the opposite side of the boom?
Hi Brad, There is not presently a default configuration set for that mounting position so it will not work. Thanks! Tabb
Hey Brad, You could do it as long as you keep the Radian in the same orientation as it would normally be - but if you can't see that lovely sticker, why would you want to ? .
Sorry Brad, bad advice on my part....in my minds eye I imagined that you would flip it such that the plugs still go to the back of the mount and you mounted with the flat side down, this would have it flipped from the correct orientation...but certainly if you kept the same orientation and put it on the other side like John said it would work. Tabb
