xOcto ot +Octo
Discussion in 'Cinestar 8' started by Pavlos Antoniou, Feb 11, 2013.
  1. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    Guys all you with the flat octos you have +octo or xocto
  3. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    From hoverfly told me tha xocto is alot better.. What you think??
  4. Shaun Stanton
    Shaun Stanton Active Member
    Oct 27, 2012
    748
    127
    I suppose if you are using a two axis gimbal the X config would be better, in the sense that you will less likely get the front boom at in the way of your shot if you are really cranking the nose down. This will be negotiable on wind angle lenses cause you will have two booms potentially in frame. If you have a three axis gimbal it will be negligible. I personally like the + config myself.
  5. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    I am asking only for the performance..! the visivbility is not a problem..!
  6. Gary Haynes
    Pavlos I be curious to hear why they think it would be better performance. A 22.5 degree change in orientation? I don't see why it would 'better' from a performance standpoint.
  7. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    i dont know and they wont answer to this..!
    The coaxial for them is a Poor choice..! For sure the now better their controller
  8. Oliver Cvetkovic
    Oliver Cvetkovic New Member
    Nov 17, 2012
    I
    Believe he is meaning I8 called +8 sometimes and V8, not X8.
    I have the same problem. Should I change to V8 setup or not.
    Clearly there is a difference. In V8, there are no motors on the axis, on other one there are.
