Hey Guy´s i would start a discussion about Vibration Damping and WKM Systems. On my old MK Kopter there it was very helpful to change the vibration damper of the FC. The result was very good. Have any one tested an vibration damper system under the Wookong IMU? Or are the best results without any dampers? I finaly work on an plate to mount the IMU with the Dampers i use on my MK System. I am curious on your answer
Hi Philipp. Did you test your Wookong with the vibration dampeners? If, yes, what kind of results did you get?
The result was that the dampers make the wobeling a little bit bigger. But i think it is not the origin of the Problem
