Wireless Transmitters + Movi Pro suggestions?
Discussion in 'MōVI Pro' started by anthonysneed, Apr 3, 2017.
  1. anthonysneed
    anthonysneed Member
    Oct 15, 2013
    36
    Looking for a new wireless video transmitter. I currently have an old Paralinx Arrow Plus. It's not so great to mount to the Movi Pro because of it's size. I recently burnt out the transmitter so I'm looking to upgrade to something new. Aiming for this criteria:
    -SDI in and out
    -Price less than 5k
    -Mounts on the Movi nicely (attached is a photo of my current mounting situation)
    Any help is appreciated thanks!
  2. Amr Issawi
    Amr Issawi New Member
    Mar 5, 2017
    15
    Teradek is making offer for bolt 500 for less than 3K if SDI only and a little bit more for HDMI & SDI IN / Out
  3. anthonysneed
    anthonysneed Member
    Oct 15, 2013
    36
    I've heard two different people I know say the teradek drops signal at times. Have you had that problem?
  4. Amr Issawi
    Mar 5, 2017
    15
    happens when near max allowed distance
  5. Rick Gerard
    Rick Gerard Active Member
    Apr 22, 2017
    172
    27
    I just purchased a Taradek Bolt 500 with 2 receivers and so far it's perfect. The transmitter gets fairly warm so I think it's going to eat up the batteries a little more than I thought it would. I have no definitive test results yet but I'll report back soon.
    Setup with painless, didn't even open up a manual or check a website, just turned the units on, plugged them in and perfect reception even when I moved one of the receivers into another room in the house and closed the door. So far so good.
    10,364
    Is there any way of adjust the amount of radio frequency power the transmitter is radiating? If there is, you might want to consider cranking it down to reduce the power consumption and heating effect.
  7. Jake Wilganowski
    Jan 5, 2017
    43
    cinegears ghost eye series
    Solid
    Mike Moghaddam likes this.
  8. Josh Lambeth
    1,313
    214
    Vaxis 1200ft system is BOMB!
    SDI
    1200ft+ range
    Uncompressed 1080 signal
    $4800
    They also have a $300 array panel receiver antenna that stretches the distance to over 3000ft.
    Never had an issue with mine and has been rock solid.
    Josh
    Brandon Obey likes this.
  9. matias pisani
    matias pisani New Member
    Oct 31, 2017
    Does anyone tried CONNEX Wireless Mini HD LINK? For a more economic approach.
    Is this any good? Thanks
  10. Mike Moghaddam
    Nov 10, 2016
    33
    I have the Cinegears Ghost Eye and have never had a problem with signal.
  11. SeBaStIaN BArrEtT
    Oct 30, 2016
    343
    67
    Its great, but noisy. only purchase if you are doing solely work with-out audio
  12. Vicente Mayo
    Vicente Mayo New Member
    Feb 22, 2017
    I also have the ghost eye, its a good and fairly cheap option to the teradek. Considering the this device can switch the hdmi signal to sdi back and foward.
  13. Mark Hoffman
    Mark Hoffman Active Member
    Jul 13, 2014
    130
    25
    I know the full size Connex has a fan but does the Mini? I thought it had no fan so it would be quieter but I've never had one in my hands to know. But yes the full size Connex has a lot of fan noise.
  14. SeBaStIaN BArrEtT
    Oct 30, 2016
    343
    67
    No but for $1300 I consider it middle of pack for < 2000 feet transmitters.
  15. SeBaStIaN BArrEtT
    Oct 30, 2016
    343
    67
    Didn't realize he asked about mini, sorry bout that
  16. Adam Brennan
    Adam Brennan Member
    Dec 29, 2013
    234
    14
    Curious what do you mean about a bit noisy? I was looking at this device too.
  17. Mark Hoffman
    Jul 13, 2014
    130
    25
    Adam the full size Connex has a fan that is fairly loud but the Connex mini has no fan (that's on the transmitter side for both).
  18. sebastian navarro
    sebastian navarro New Member
    Mar 6, 2017
    11
    we have the connex mini for our Movi pro. So far is been fine for what we do. The range is more than enough. The only drawback is that it lacks of SDI input. on the Reds is not a problem (HDMI Out) but in the alexa mini(SDI Only) we have to cross convert the signal to HDMI. We use an smallHD 502 to do it but somehow the signal out from the alexa has to be set it up to be interlaced to be fully compatible to some monitors in the chain. Otherwise it shows signal not detected.
    greetings
    sebastian
