Hi, Currently using a futaba radio setup to control pan and tilt (aerial setup). Looking to add some control over the lens and looks like you have to use the Movi Controller to do this. Question is can i use both the Futaba controller at the same time as using a Movi controller or will the move controller override the Futaba? Thanks Neil
Yes, you can use both at the same time. With both receivers connected to the MōVI (Futaba in COM 2, MōVI Controller in COM 1) the MōVI will assume pan/tilt commands are coming from COM2 and give you control authority on the Futaba for pan/tilt. You can also use MIMIC, MIMIC + Bush Pilot or Pilot in tandem with an RC radio like the Futaba.
