After I installed the wifi adapter and tested at home it worked perfectly. Connected every time to my iPhone on the app. Was on location yesterday and it worked absolutely fine for the auto tune etc, but when I turned the movi off the wifi network disappeared completely and I couldn't get it back. The status light was flashing green. Typically this was when we were about to shoot, so I was forced to just go with it but couldn't change any parameters, access anything. There is a reset on the wifi, should I just press that and see if the wifi comes back? Has anyone else had this problem? I've upgraded to Akira as well. Thanks!
I never had an issue, but I would double check the connection and push a little on the connectors. Maybe even hard reset the phone
