Which lens? 14, 15 Fisheye, 24 or 36 on a 5D
Discussion in 'MōVI M10' started by Dailey Pike, Dec 11, 2013.
  1. Dailey Pike
    Dailey Pike New Member
    Oct 5, 2013
    Just wondering which lens you'd prefer between the 14, 15 Fisheye, 24 or 36 on a Canon 5D?
  2. Austin Glass
    Austin Glass Active Member
    Aug 1, 2013
    440
    69
    On full frame sensors, I like the 20-50 range when on the Movi. Keep in mind that when using a wide angle lens on the Movi, you run a greater risk of casting operator shadow on your subjects. With wides, you usually need to be closer to your subjects, meaning light sources should be higher. If you are on a tighter lens, you will naturally operate from a few more feet away, thus making the operator shadow not as much of a problem.
  3. Steve Maller
    Dailey, as with normal photo situations, it completely depends on what you’re shooting! I use virtually all Canon lenses, depending on the situation. However, one thing to consider is weight, and as such, the 15/2.8 fisheye and 24/2.8 IS are very light.
  4. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    881
    70
    Dailey we use the 24/2.8 IS lens for normally but if we want a wide shot we bring out 15/2.8 fisheye instead of doing 3 photos you can do it in one!
  5. Fred Light
    Fred Light New Member
    Oct 30, 2013
    14
    I shoot real estate and use a 14mm
