Which Futaba better for MOVI M5? Help!!!
Discussion in 'MōVI M5' started by Kanun Boriraj, Jun 2, 2014.
  1. Kanun Boriraj
    Kanun Boriraj New Member
    May 8, 2013
    I'm looking for Futaba radio control use for my Movi M5. I also read mostly of topic and comment but I can't found my answer. Which Futaba radio control that match with my Movi M5?
    8FG would be a good choice with an sBUS receiver.
    Kanun Boriraj likes this.
  3. Jeff Scholl
    Jeff Scholl Distributor
    240
    50
  4. Gary Haynes
    Very strange but true since the poster in this string is from Futaba U.S. And a word of caution the the RX that comes with the 14SG does not have the same sBus output as the other Futaba RXs. It won't work with the MoVI systems. However you can pick other FASST RXs out of the current line and they work fine. Just not the newer FASSTest RXs that have telemetry.
  5. Justin Oakes
    Justin Oakes New Member
    Jan 5, 2015
    Hey Gary,
    Any idea if Freefly ever updated the firmware to accommodate the use of these telemetry enabled Futaba rx's?? Specifically the 7008sb, 3008sb, and 2008sb.
  6. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    T8j is cheap and nice solution.
  7. Gary Haynes
    Justin, yes it has been upgraded. But for telemetry the only direct thing you can do is battery power. No other telemetry. You would need a tap from the M5 battery to the small Molex connector on the antenna end of the 7008SB (just above the Link button). Futaba sells a cable with a fuse. CA-RVIN-700 (FUTM5551)
  8. Tim Marchenko
    Tim Marchenko New Member
    Mar 13, 2015
    20
    Has anyone thought of using the NEW "DJI Lightbridege 2" on Movi M5?
    It is S-Bus signal as much as i know and you can use the same Air Unit for the HD video down link.
  9. Esteban Barrera
    Esteban Barrera New Member
    Aug 22, 2015
    People at Quadracopter recommended the 14G, you need to get the R6303SB receiver to work with the M5. It's an expensive control, but will work as a backup control for the Alta.
