Which electronics are you using [poll]
Discussion in 'Electronics' started by Tyler Olson, Feb 3, 2014.
Which Controller are you Using?
  1. Mikrokopter
    54.8%
  2. DJI
    35.5%
  3. Other
    9.7%
  1. Tyler Olson
    Tyler Olson Member
    Apr 28, 2013
    154
    I thought it would be interesting to see a poll of which electronics people are using. I think about their main copter here. Many people have a large, medium, perhaps a couple small play copters. But what I'm curious about is the largest one - the one you have the most invested in.
  2. Steve Maller
    2x MK stacks, one Flat 8 4S and one X8 6S (new hardware).
  3. Paul conto
    Paul conto Member
    Feb 13, 2013
    244
    19
  4. Ryan McCrae
    Ryan McCrae Member
    Oct 9, 2012
    120
    SuperX, its working but not perfect, lacks the tuning needed for heavy machines.
  5. Michael comissiong
    Feb 9, 2013
    59
    Most money invested in mk,
    but fly dji more
    mk always wants tuning a pain , but too many $ invested to abandon at this point
    Jason Herring likes this.
  6. Chris Fox
    Chris Fox Active Member
    Apr 14, 2013
    463
    86
    How heavy Ryan?
    I'm getting good results at with AUW around 13kg/28lbs
  7. Zubeyir Mentese
    Zubeyir Mentese New Member
    Jan 16, 2013
    19
    Hi Ryan,
    Could you elaborate a little bit more about the specific tuning issues you encountered?
  8. Chris Newman
    Chris Newman Member
    Oct 9, 2012
    200
    14
    Did you ever get your SuperX tuned? I can't get mine tuned for the life of me!
  9. Gary Haynes
    Chris I had my flat 8 at 1.0 for all setting except height which was an .9. Had the fine tuning on a rotary and dialed that down 30-40%.
  10. Ryan McCrae
    Ryan McCrae Member
    Oct 9, 2012
    120
    I couldn't get the gain high enough for it to be stable and controllable, with out it shaking, (as if the gain was way to high).
    Nope never managed it, i did a lot of changed to my machines set up such as making sure the motors were 99.9% perfectly aligned and also lowered the super x to get it in the center of the copters CG. They helped a little.
    It worked great in little to no wind, but it just started shaking when moving fast or when windy.
    Super X support did suggest I raise the altitude gain up to 1.5 -1.7, but i didn't do it because i pulled the Super X off and put a MK 2.5 board on. Super X did some weird things before i pulled it off, just as a random uncommanded motor spool up, when it was disarmed! Also flipped on take off as if the sensor was mounted upside down.
    Today was my second day with MK, I have flown just over an hour with it now, managed to get it tuned in a bit. Its feeling better than super x so far, But i haven't tested in much wind yet.
    Are you using it on a X8 Chris?
  11. Ryan McCrae
    Ryan McCrae Member
    Oct 9, 2012
    120
    From what I've heard Super X is amazing on flat set ups or even small X8s, but just doesn't work on large X8s.
  12. Chris Newman
    Chris Newman Member
    Oct 9, 2012
    200
    14
    Yes, it is an octo x 34lbs Auw. I think Chris fox might fly an octo x same setup as mine Auw 28lbs? I'm going to be flying a red carbon fiber dragon for a week in Hawaii . Failure is not an option! I was hoping for better results!
  13. Ryan McCrae
    Ryan McCrae Member
    Oct 9, 2012
    120
    Whoops forgot about Chris. Your right he does. Hopefully he`ll chime in and help with your tuning.
  14. Chris Fox
    Apr 14, 2013
    463
    86
    Guys, I just use the settings that Gary recommended and have the gain on a slider on the tx as well, as the weight increases I wind up the gain, and as the weight decreases I wind it down a little .....
    Flew last week with 5kg of batteries on top and 7.2kg of weight suspended from the copter, for an AUW of 17.4kg and getting good results.
  15. Bryan Harvey
    Bryan Harvey Member
    Nov 3, 2012
    227
    18
    Hey Chris, did you ever get the SuperX tuned for your X8? I want to switch away from the A2 and SuperX looks good for some, but I also fly a heavy X8, so wondering if it will work for me.
  16. Chris Fox
    Apr 14, 2013
    463
    86
    G'Day Brian,
    Yep super x is working just fine for me, very happy with it.
    All up weight during test flights 38lbs actual weight when on set is about 35lbs.
    Cheers
  17. Chris Newman
    Chris Newman Member
    Oct 9, 2012
    200
    14
    I never could get it tuned! Didn't like the way it felt. I've read a lot online that the heavy lifter octox configurations don't work well on the system. I've had issues with a2 as well....
  18. Bryan Harvey
    Bryan Harvey Member
    Nov 3, 2012
    227
    18
    G'day Chris. Is that SuperX working on X8 or flat octo? IF X8, what's the secret, as others seem to have had difficulty with that configuration and SuperX.
    Thanks!
    Bryan
  19. Chris Newman
    Chris Newman Member
    Oct 9, 2012
    200
    14
    I gave up on the superx on octox configuration.
  20. Graydon Tranquilla
    Oct 8, 2013
    159
    15
    I've been flying DJI systems for a couple of years starting with the NAZA then moving up to the WKM then the A2..... All worked fine for me so far but the reports of crashes has spooked me. So next I will try an XAircraft SuperX.
    And if the Hong Kong situation continues in the wrong direction, I will move away from Asian products and go for the German Mikrokopter.
