I booted up my M10 today with a Canon C100 and a 24-105 lens on it. At first it vibrated really hard because it still had the settings from a much heavier camera still on it. I turned the settings (motor stiffness) down so there was no more vibration. I wrote the settings to the M10, turned the M10 off for 5-10 seconds then turned it back on. The saturation indicator was red and had a value of 0. I'm assuming its a problem since its red. 1. What is saturation? 2. How do I adjust it so its not red? Thank you
It sounds like you are seeing a red indicator for SAT, which means you do not have enough satellites for satellite lock. Satellite lock is not required for the MōVI to function, but it does help with keeping the horizon level during fast moves.
Thanks Bryan, I think you're right. I think I assumed SAT meant saturation. Hey Austin, I shouldve taken a screenshot when I had the issue. Good idea though. Thanks guys
