Very slow pan drifting
Discussion in 'MōVI M10' started by William Kee, Nov 21, 2014.
  1. William Kee
    William Kee New Member
    Nov 21, 2014
    Hello, I've been out on MOVI jobs a few times but don't know the MOVI10 in total detail.
    One thing I've noticed is that the MOVI that I use pans very very in majestic mode. So, if I have the camera set up in majestic mode, and leave it for 20 minutes, it will drift a few inches to the side.
    My controller seems to be neutral and I have reset/defaulted the system a few times, in hope that it would stop.
    It might well be a trivial fix,
    Any ideas?
  2. Augusto Alves da Silva
    Augusto Alves da Silva Active Member
    Apr 16, 2013
    202
    39
    I think you don´t have any drifting. What I think you have is normal. You probably have a x degree deadband when panning so when it rests on the stand it will move to one of the sides but when you hold it it is already centered.
  3. William Kee
    Nov 21, 2014
    I had a job recently where we mounted the MOVI to the ceiling and I used the controller to aim the camera down so that we had a bird-eyes-view shot. I left the MOVI in the controller mode, and every time we went for a new take, I had to straighten the camera up so that it aligned with the original frame.
    Arturo Bernardi likes this.
  4. Augusto Alves da Silva
    Apr 16, 2013
    202
    39
    So you´ll have to set the deadband to 0. Should fix it
  5. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    deadband how do i set it to zero? through the controller dx8?
  6. Gary Haynes
    Charles that would in the GUI. Also if you are using the DX8 make sure that the trim setting (rocker) is at the center 0 setting. If not it will slowly pan the gimbal.
  7. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    lol i realized that my left joystick whicb controls the pan speed control is also controlling the pan (very slowly)!
    How do I get rid of this pan control on the left joystick!
  8. Augusto Alves da Silva
    Apr 16, 2013
    202
    39
    android app or computer on the GUI.
  9. Gary Haynes
    Adjust the trim setting with the switch below the pan stick.
  10. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    ok that is at zero
  11. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    i have been messing around with that , that doesn't stop the left stick from controlling the speed of the pan , plus control the pan (very slowly) left or right. Example when I set the stick to the up position it pans left and down position it pans right . during this time the right stick is free and not used.
  12. Andy Johnson-Laird
    10,372
    Charles - I infer you're using a Spektrum transmitter? (Apologies if I have overlooked something you've written above).
    Can you verify what's happening by looking at the Servo Monitor window on the transmitter -- it will show you what signals on which channels the transmitter is sending. That will help identify whether the issue is in the transmitter settings or not.
    To get to the Servo Setup screen, press the right-hand thumbwheel down once, scroll right one click, and press the thumbwheel again.
    If you move the left-hand stick carefully backwards and forwards you should only see left-right movement on the top (THR) channel.
    Are you seeing any other channels moving? Specifically, do you see any left/right motion on the second channel (AIL).
  13. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    just followed your instructions don't see the other stuff moving except throttle
  14. Gary Haynes
    Charles is the channel with Pan showing that it a zero value or centered?
  15. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    the pan channel stays in the middle no changes
  16. Andy Johnson-Laird
    10,372
    Hmmm. I'm completely puzzled, Charles. The evidence suggests that somehow Channel 1 (THR) is exerting an influence over Channel 2, yet you're not seeing that on the Servo Monitor window -- which suggests that it's happening in the MōVI....
    I think you're going to have to open up a support ticket at support@freeflysystems.com and include a link to this thread so that the folks don't make you repeat your experiments.
    Wish I could be of more help.
  17. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    i am already on email with the freefly folks. will post the findings on this thread
    This problem is very frustrating...:mad:
  18. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    i messed around with the stiffness and all of a sudden the drifting has stopped! :eek:o_O:)
    Don't understand the reasons for this
  19. Andy Johnson-Laird
    10,372
    In the world of computer software this is known either as a "feature" or "magic." :)
    Glad you fixed it. What stiffness setting did you end up using?
  20. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    tilt was at 80 . pushed it to 100 plus .
