Using MoVI Pro Feet on M15 Ring
Discussion in 'MōVI M15' started by Cody Cochran, Jun 29, 2017.
  1. Cody Cochran
    Cody Cochran New Member
    Nov 25, 2014
    27
    Do you guys know if the replacement feet for the MoVI Pro will fit on an older M10/15 Ring?
  2. Graham Futerfas
    Graham Futerfas Active Member
    809
    171
    No, they won't. Cinemilled makes feet that might work. The original ring is 25mm thick, the Pro Ring is 30mm (and those feet have tabs that keep them aligned).
  3. Peter Barta
    Peter Barta Member
    Sep 24, 2013
    70
    20
    Hey Cody,
    I've made the Movi PRO feet work on my M15 ring with a rubber reducer from 30mm to 25mm works fine
    Jan Solberg likes this.
  4. Michael Simo
    Michael Simo New Member
    Dec 6, 2017
    Hello Peter Barta,
    Are you able to confirm after several uses if these feet with the rubber reducer on the original M15 ring works well? Does it tilt over or anything like that? I will be using the M15 near-maxed-out with the weight. More importantly, where did you find the rubber reducers? Is there a specific link you mind sharing? Thanks for all the help.
  5. Peter Barta
    Peter Barta Member
    Sep 24, 2013
    70
    20
    Hi All,
    After an extended time trying to make this work the feet still move on the M15 ring unfortunately especially with lots of camera weight so I’d suggest the feet from Cine Milled which work on the older M15 ring size.
  6. Michael Simo
    Dec 6, 2017
    Thanks so much. Greatly appreciate your advice!
