Hi all, Thank you in advance for your time. Just rigged an m15 to a x8 multi, carrying a bmcc. Everything balanced well (including pan axis) Stiffness on pan motor is not having much effect even at 400+ compared when in handheld mode. Tilt and roll holding well. But getting wobble on the pan axis when in flight. Any insight??
Have you looked at the motor charting in the GUI? Might help you with the trouble shooting. And I've never heard of setting at 400? What exactly is happening on the pan?
Thank you for reply, I will take a look at the gui. Regarding the high gains it was just too add more stiffness to the pan motor, as in airborne mode the pan felt a lot softer than when in handheld mode. But even when adding full gain in airborne mode, it still feels loose. You can push it easily with your finger, where as the roll and tilt are rock solid.
